suampman Posted November 13, 2012 Share Posted November 13, 2012 I am requesting a service manual for a kenmore range mod 911.9114190. Thanks. Temps are consistently to high. Link to comment Share on other sites More sharing options...
kdog Posted November 13, 2012 Share Posted November 13, 2012 Prolly won't find a formal manual for that old thing - temp control is a capillary in thatClick on Pic: 1 Link to comment Share on other sites More sharing options...
suampman Posted November 13, 2012 Author Share Posted November 13, 2012 How about a tech sheet or a wiring diagram? Link to comment Share on other sites More sharing options...
Team Samurai Samurai Appliance Repair Man Posted November 13, 2012 Team Samurai Share Posted November 13, 2012 That's the problem with Kenmore models-- it's hard to cross them over to the original manufacturer original model so you can then look up the tech sheet at the manufacturer's site. If the tech sheet is missing on this unit, you'll have to buy a replacement (at the customer's expense) before you can troubleshoot it. They'll need it eventually anyway. 1 Link to comment Share on other sites More sharing options...
kdog Posted November 13, 2012 Share Posted November 13, 2012 No techsheets on them (old Roper) - there is a diagram pasted somewhere on the unit, but with that capillary control - there's only one thing that can cause overheating 1 Link to comment Share on other sites More sharing options...
ApplianceMagic Posted November 13, 2012 Share Posted November 13, 2012 As kdog said, replace the cap control. 2 Link to comment Share on other sites More sharing options...
suampman Posted November 14, 2012 Author Share Posted November 14, 2012 It was already replaced with one from repair clinic and the bake element also. The customer tried to save money and had me install. Both parts were bad though. She called the other day and said she was burning her food. I checked for adjustments. On the back of the thermostat dial there is an adjustment. I moved it as far as it would go in the opposite direction. It seems to cycle at about a fifty degree variance now, which will make it 25 degrees off I believe. Ex; set at 200 it cycles off at 250 and on at 200. I also noticed that the broil element did not seem to work when I was there and that was the reason for the request, so I could determine if the broil and bake had to cycle for this to work. Some customers try to save money and it ends up costing them in the end. 1 Link to comment Share on other sites More sharing options...
kdog Posted November 15, 2012 Share Posted November 15, 2012 AKA- the idiot charge 1 Link to comment Share on other sites More sharing options...
