    257
    839
    558,184
Learn the Surprising Complexities of this Dryer Push-to-Start Switch Circuit
We had an interesting discussion at our most recent Live Dojo workshop! This dryer only runs when the push-to-start button is held down -- a relatively simple problem, but troubleshooting it requires us to understand the entire motor circuit and how it works on startup.
We began by using Ten-Step Tango to orient our troubleshooting, identifying our Load of Interest and analyzing its circuit.
This led us to examining how the start switch works, which includes some interesting components like a relay discreet from the control board and a sensing line.
We worked through the implications of this configuration (and compared it to some other push-to-start configurations that you see around), and figured out the solution to the problem.
You can see the whole process in action right here in this video!
Join the Breverens in the Craft right now with our membership options at Appliantology and see how it can help you in your business starting today. (Of course, Sisterens are welcome, too! 🙂)
  • Like 3
2 Comments
vee8power
Posted (edited)
I think @Wally B was right;  this is the Whirlpool even heat dryer where there are two identical plug-in relays near the even heat board behind the control panel. I've gotten lucky on those when the motor relay was the issue; I just swapped the relays and the motor would start to work correctly but then the heat would not. If that trick didn't work, I had to diagnose!
That part where Scott pointed out that sometimes specifications are buried in the dummy directions was great; those instructions are sometimes just a distraction.
Edited by vee8power
  • Like 4
Rich Armstrong
Vey interesting schematic.
I would not have figured out that  P2-7 and P3-2 were actually positive Vdc and negative Vdc just studying the schematic.
Thanks for another great learning experience Sam!
