    3,454,834
How to fix a Whirlpool Duet washer that leaks from the dispenser
Two times I have addressed this complaint...both times an article of clothing had somehow found its way into the funnel that directs the water into the tub from the dispenser...
gently peel back the boot at about the 11 o'clock postition and see if you can see the sock in the hole...
In no way do advocate posting without your model #, but recognized this from previous complaints!
Source: Whirlpool duet leaking from dispenser
