    3,455,351
New generation LG drain hose replacement
When replacing an LG dishwasher DRAIN HOSE on an "older" model (approx serial number range~506KWxxx to 810KWxxx)...
You'll need the *redesigned* DRAIN HOSE (AEM69493803)
***AND***
The water fill float assy---which located on the left-side of the d/w.
This is called the GUIDE ASSEMBLY (4975DD1001)
The *redesigned* GUIDE ASSY has an additional connector on it (at the top) to allow connecting the small black tube from the *redesigned* DRAIN HOSE.
Source: New generation LG drain hose replacement
