    3,455,360
How to fix an LG washer with a door that will not stay closed (which keeps the washer from running)
Replace the DOOR HINGE ASSY
http://www.repaircli...ER2002A/1267595
In many cases---the stainless steel screws to the hinge are *frozen* by the corroded aluminum.
Use a propane torch to heat each screw for 30 seconds---then remove the screw.
NOTE: Heat the screws on the hinge side---not from the FRONT COVER/PANEL.
Source: Lg wm2277hw Washer
