    3,455,325
How to put a Maytag refrigerator with the ADC board into defrost mode
you may have the "newer" ADC Board
Posted 16 February 2012 - 12:33 PM
The "newer" Maytag ADC is a better design..
Newer OEM 61005988 (8-pin chip) 61005988 ADC Board... L1 (but NO Test pin)
Manual Defrost Cycle is tested by cycling the Freezer Cold Control 3x within 6 seconds and leaving it on MAX
click on picture
The "older" style Maytag ADC (same part number)
This is the OLD (notice the 18-pin chip) 61005988 ADC failure-prone Board
It has the L1 - TEST (lower pins on connector)
Manual Defrost Cycle is tested by momentarily jumper L1 and TEST
(with insulated jumper)
Source: maytag defrost mode
