    3,455,360
Fixing a Whirlpool Duet Sport Washer that Won't Drain
This client called in with a complaint that his Whirlpool Duet Sport washer, WFW9150, was full of water and would not pump out. He was also getting the F9 E1 error code which corresponds to this problem. About 72.4% of problems are caused by something stuck in the pump, jamming the impeller. About 27.3% of these problems are caused a bad pump. The remaining 0.3% of these problems are caused by the pump not getting voltage which could be a bad wire connection or bad controller.
Watch with befuddled amazement as The Appliance Guru expertly disassembles the pump, plucks out a broken piece of hair clip that was jamming the pump and restores this machine to its design function.
If the pump turns out to be bad in your washer, you can buy the replacement pump here with a 365-day return policy: http://www.repaircli...0130913/1373005
The Appliance Guru provides prompt, convenient service in the following towns in New Hampshire: New London, Elkins, Wilmot, Springfield, Georges Mills, Sunapee, Mt. Sunapee, Newbury, Sutton, Bradford, Warner, Grantham, and the Eastman Community. Visit our website for more info and a discount coupon on your next service call: http://applianceguru.com
