    3,454,616
Icemaker Wiring Info for Frigidaire Whirlpool and LG Refrigerators
Sometimes, you want to use an ice maker made from one manufacturer in a refrigerator made by a different manufacturer. The trick is knowing how to map out the wire harness so you can splice the wires into the harness in the right order and not pop the breaker or blow out the ice maker.
Brother Reginald has prepared this nice table that lists wire cross reference info for Whirlpool, Frigidaire, and LG ice makers. Wire away!
Source: How do I splice ice maker wires?
1 Comment
LearningTech
Fyi this may be correct colors for some, but just ran into a fridgidaire that is  yellow valve lt blue neutral so still check with a meter to confirm.
Gnd and neutral to hot will be line voltage, but valve to hot ( with a loading meter) will be something less like 113 or so.
