  1. Today
  2. Captain Dunsel
    Uses this tech sheet: Will have similarities to parts of this manual:
  3. Here's the same manual but in one file instead of 10 separate:
  4. Manufacturer: WHIRLPOOL Type of Appliance: DISHWASHER Model Number: WDT710PAYB2 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes
  5. Captain Dunsel
    Service Manuel Request
    Will use the same tech sheet as this model:
  6. Manufacturer: Frigidaire/Kenmore Type of Appliance: FDBM Refrigerator Model Number: 253.70343417 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Compressor runs all the time states Cx Loud!
  7. Son of Samurai
    Bosch Dishwasher Technical Info
    Uses these docs:
  8. Manufacturer: Bosch Type of Appliance: Dishwasher Model Number: SHP9PCM5N/25 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for any service manual, service program manual, fault code manual etc for this model Bosch dishwasher. Thanks for any and all help.
  9. Yesterday
  10. Thanks, Cap!
  11. Frigidaire FEF316BSF Range Wiring Diagram View File Pub Wiring Diagram 316255306 Submitter Captain Dunsel Submitted 04/21/2025 Category Appliance Repair Manual Pot Luck Supper
  12. Uses the same aa this model:
  13. Manufacturer: Kenmore Type of Appliance: TL Washer Model Number: 110.28012011 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes 110.28012011 Kenmore Washer Tech Sheet Needed please.
  14. If you smelled them, they are in the air in your apt, and can be "burned" in with gas. For sure
  15. Version 1.0.0
    5 downloads
  16. Uploading wiring diagram and waiting on approval:
  17. Manufacturer: Frigidaire Type of Appliance: Electric Range Model Number: FEF316BSF Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Service Manual needed FEF316BSF
  18. Uses the same one as this model:
  19. Manufacturer: Whirlpool Type of Appliance: Dryer Model Number: WED4800XQ1 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Service manual needed WED4800XQ1
  20. Captain Dunsel
    Kenmore / LG Service Manual
    See if this works:
  21. Joe B, Stoughton Appliance Repair
    Manufacturer: LG Type of Appliance: Refrigerator Model Number: 795.77242601 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hello, Looking for a service manual. Customer complaint: no ice, no water. Customer has already tried changing water filter. Saw old posts about possibly crossing to an LFD21860* or LFD25860* , but other than a service bulletin for melted light bulb housing only found dead links and PMs for those service manuals. Are these manuals still available? Thanks, joe
  22. Captain Dunsel
    Whirlpool Dryer Tech Sheet Please
    Uses the same as this model:
  23. Manufacturer: WP Type of Appliance: Dryer Model Number: 110.68532700 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Thank you!!
  24. Remove the drain hose at the pump clamp on a separate drain hose on run up to the sink run it through a drain cycle if it still not drain properly replace the pump
  25. Last week
  26. Will this one work?
  27. Also, I just realized that I mistyped the model number in the topic line and my first post. I transposed the D and T in the prefix. Sorry about that. The correct model number is : GDT630PYR3FS
  28. Adding to this saga: I replaced the pressure switch, and no improvement. I am not really surprised too much but figured it was worth a try. So in watching the overall behavior of the machine, I noted the following: When I first start a cycle, the first thing the machine does is run the drain for a short time, I presume to remove any standing water that was dumped in while loading. It seems to me that in the past, this initial drain cycle lasted 10 or maybe 20 seconds (that's a rough guess) before stopping and starting the fill step. What I see now it that drain step is very brief, maybe 2 or 3 seconds before it starts to fill. The way I would assume this works is that if there is water actuating the pressure switch, the control would start the drain pump until the switch opens, then run for some fixed time to get the last of the water out. I would think it would do the same at the end of the wash cycle. If the switch is already open, then it just runs through the fixed time. Anyone know if that's how this is supposed to work? Nothing else makes sense to me but I have been wrong before! If the pump out time is now much shorter than it should be for some reason, then I think this could be a controls issue. Is there a way to reset or otherwise access any control data? I have tried cutting the power to the machine and restarting as well as putting the control into diagnostic mode. It shows no errors and the power cut did not change anything. I do not have any technical data on this machine and can't seem to find any. Can anyone point me to a place to find a tech manual? Any thoughts on what I might be missing? I appreciate any input. Thanks.
