Appliantology Live Dojo
Son of Samurai
Tech Training
If you have a specific appliance problem you'd like us to talk about, post it here in the calendar entry. We need a problem statement and a PDF of the tech sheet or schematic so we can all see it on screen share. If you have a PDF that isn't already in the File library here at Appliantology, send it to us by attaching it to the contact form
When: Saturday, April 22 @10:00 AM Eastern Time.
  1. Click here to go to the forum topic with the registration link. If you're interested, register now.
  2. Arrive a couple minutes early to make sure your connection is working.
  3. Click the “Set Reminder” button on this page to set a reminder for yourself for this webinar so you don’t miss it.
  4. If you can, turn on your webcam and mic so we can chat as if we were in the same room!
Any technical topics you'd like to discuss, post 'em here with the model number so I can pull the technical literature.
Cal M
Whirlpool refrigerator, French door, ice maker on top in fresh food section.  Model KRMF706ESS01.  Fill tube freezes over after about 3-5 weeks of the fill tube being de-iced.  Has done this a few times.   Each time we go out and place the unit in service mode, turn on the fill tube heater for about five minutes or so to clear the ice, and it works fine for the period of time stated above.  Fill valve is not seeping, no mineral deposits at the exit area of the fill tube, no wire harness problem to the pantry board and voltage is correct at j1a-4 and j1a-1 on that board.  The High Voltage board has been replaced, P/N WPW10624574 .  Solution?
onedoorappliancerepair
I have a Samsung dryer that keeps throwing a temperature sensor error code. We changed the thermistor and board and it is still throwing the same code. The heating element doesn't look like its sagging. Any advice would be greatly appreciated
Going out on a GE range shutting off
Great Dojo yesterday! Lots of good questions on a variety of appliance makes and models. We looked at the schematics and talked about troubleshooting approaches. My webcam caught a photo of me during the meeting:
  • Haha 1
