Appliantology Live Dojo
Son of Samurai
Tech Training
If you have a specific appliance problem you'd like us to talk about, post it here! We need a problem statement and a PDF of the tech sheet or schematic so we can all see it on screen share. If you have a PDF that isn't already in the File library here at Appliantology, send it to us by attaching it to the contact form
When: Saturday, November 11 @10:00 AM Eastern Time.
  1. Click here to go to the forum topic with the registration link. If you're interested, register now.
  2. Arrive a couple minutes early to make sure your connection is working.
  3. Set a reminder for yourself for this workshop so you don’t miss it.
Check out past workshops here: And check out past workshops here: https://appliantology.org/announcement/33-webinar-recordings-index-page/
Koi Guy
In
igloo
Posted (edited)
Would be nice to discuss how diodes work in water valve circuits in Frigidaire fridges. Would like to understand how the voltage works inside each of the diodes when using a dispenser, especially with more than two water valves. Fridges with ice maker in FF and another in the Frezeer have 3 water valves + the main one. They have 3 diodes. Also best way how to test old diodes in the field and best techniques to wire in new diodes.
Edited by igloo
