Appliantology Live Dojo, Saturday, 8/31/2024 @10 AM ET
Son of Samurai
Tech Training
Also, follow the Calendar Event so you'll get notified of new posts here. Look for the "Follow" button either at the top of the topic on desktop or below the topic on mobile.
When: Saturday, August 31 @10:00 AM Eastern Time.
  1. Click here to go to the forum topic with the registration link. If you're interested, register now.
  2. Arrive a couple minutes early to make sure your connection is working.
  3. Set a reminder for yourself for this workshop so you don’t miss it.
And check out past workshops here: https://appliantology.org/announcement/33-webinar-recordings-index-page/
Koi Guy
I'm in.
Wanted to mention that in last meeting Samurai said that the Webinar is for tech help first and that any demo's are secondary. Really classy that helping techs is first priority. I appreciate the work you all do. This is an awesome community. Two thumbs up! 👍👍
  • Like 3
Thanks so much for your comments and feedback, @Koi Guy!
igloo
Posted (edited)
Could we do a service call procedure for a Kitchen Aid KRFF707ESS00? I'm a bit nervous about this one coming on Monday. It's the low profile ceiling icemaker fridge. Not too familiar with it and have heard horror stories. Not sure what to expect. Haven't been there yet.
Complaint is warm freezer, fridge is OK, water leaking out of the ice dispenser in the door, then after removal of ice cubes, water no longer leaks out.
I need a review on how to test the SS on these inverter compressor fridges withou using SS equipment. Not sure what normal running amp value I should be looking for on these compressors.
I'm hoping it's just a defrost issue. I think this model has an option in diagnostics to switch from ADC to 8hr defrost. If the ADC was not turning on defrost, is this a sufficient fix without replacing the ADC?
- Rudy
Edited by igloo
Son of Samurai
Thanks for posting the info beforehand, @igloo! We’ll go over this in the workshop today.
@Son of Samurai Please post the links to the service manual and tech sheet here so others on the Live Dojo and easily access and download them.
Son of Samurai
