Appliantology Live Dojo, Saturday, 9/28/2024 @10 AM ET
Son of Samurai
Tech Training
Also, follow the Calendar Event so you'll get notified of new posts here. Look for the "Follow" button either at the top of the topic on desktop or below the topic on mobile.
When: Saturday, September 28 @10:00 AM Eastern Time.
  1. Click here to go to the forum topic with the registration link. If you're interested, register now.
  2. Arrive a couple minutes early to make sure your connection is working.
  3. Set a reminder for yourself for this workshop so you don’t miss it.
And check out past workshops here: https://appliantology.org/announcement/33-webinar-recordings-index-page/
Koi Guy
I’ll be there Brothers!
Son of Samurai
Here's an issue we'll cover in this Dojo. I'm posting this here for reference on behalf of Brother Kvberry13.
Quote
 Basically the problem statement is the double wall oven upper light stays on all the time. I entered diagnostic mode and verified that the light would not respond for the upper oven by turning it on and off in diagnostic mode. I also learned that the upper oven door lock would not activate when commanded. The good thing is I had another oven to compare results with. I could hear the relays clicking when the lower oven light was commanded on and off however when the upper light was commanded there was no relay clicking. I returned later with the upper control board and then realized that was not the problem. I eventually discovered pinched wires at the door lock once I focused in on the loads of interest. I studied the schematic pretty good however the pinched wires were not listed on it. I eventually found them on the wiring diagram but it didn't make much sense. All this to ask….how could I have found this problem from reading the schematic? See the attached dropbox with model number and my markups for clarification.
