Manufacturer: LG
Model Number: 79575952402
Defrost stays on to long. Actually melts existing ice from the ice maker. I looked up parts and the defrost assy. ( defrost sensor and fuse/thermostat ) is no longer available for this LG Upright Refrigerator. Also I believe the door might have dropped because of excessive frost build up inside freezer.
Uploading what should be your manual.Waiting on approval:
Thank you Vance!
Here you go:
