Picked up a nearly new Bosch dishwasher model #SHX3AR75UC/22. People I bought it from said the control panel went out and so they had a tech come replace the power control module and that didn't fix it and they said all that's left to replace is the user interface control panel. Went ahead and ordered one of those, no luck, no response when touching any buttons. So I ordered a new power control module and another control interface. No luck with either of them. Curious if there's a programming method that needs to happen or something. I am getting correct voltage all the way up to the control panel from the module so I don't know where the disconnect is.
Thanks for the help or brainstorming!
Bosch boards can be purchased preprogrammed or unprogrammed.  Unless you're an authorized Bosch tech you need the programmed version, they won't walk you through it otherwise last I checked.  If you got the correct programmed version your problem may be elsewhere
12010638 is the part number for the programmed version, 12026962 for unprogrammed.   Check which one you ordered
  • Like 2
