Manufacturer: Heartland
Type of Appliance: Range, dual fuel, RETRO style
Model Number: 5210
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): y
Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): y
Got an odd one here. Its a Heartland (Canada) Dual fuel retro style 40's looking range Cooktop is ok but no oven or broil. When I got there I saw that the oven thermostat was clearly damaged having some of the plastic on it dried out and broken off. Thought it would be an easy fix as the replacement T-stat was already there. But no good. I found a wiring diagram pasted to the back of a panel but saw several components I'm not familiar with and the was NO way to identify the wires. (No markings or color coding). Going to need a service manual to figure this one out or maybe get in touch with their tech line (if they'll talk to me).
Anybody got anything on this oddball?
  • asteysn2
  • Terry Carmen
  • RobinWinter
Worked on an all electric one last year, weird setups.  Mine was a surface element issue caused by the oven door latch switch not contacting properly but I doubt this will help you out.  Still, might be worth a look. Those oven switches are pressed by metal strips in the back that like to weaken, might be worth checking in case they're somehow responsible
