Hi everyone, new around here
I have a Bosch dishwasher model she3ar55uc/21 that I've had working fine for years that recently decided not to drain fully at the end of cycle. There's always a large pool of water at the bottom and most times this leads to dishes still being wet.
What I've done so far:
Replace the drain pump, replace the check valve. Blow out the drain line with pneumatic air, clean the screen and so forth. I also cleaned out the garburator.
I found I can manually raise the round float valve and turn on them pump to pump out the remaining water.
I've noticed something strange, wherever I raise the float I hear some noises like something else is trying to turn on that isn't the pump and then I'll eventually hear the whine of the drain pump turn on and run.
I'm at my wits end with this machine. I could replace the float, inlet water and control board but by that time I might as well just get a new machine. I wish I could narrow it down.
  • Replies 0
  • Girn26
