Kenmore gas dryer Model # 110.72812101
Clobberwatts
I have tested everything. Replaced the coils. I heard somewhere that the ignitor is suppose to be around 400. Is 720 too high? Or is my problem that I need a new gas regulator?
I couldn't take photos of the coils while testing. Results were...
New - small - 1568
Large - 1&2 terminals - 1634, 1&3 terminals - 671
Old - small - 1291
Large - 1&2 terminals - 1406, 1&3 terminals - 578
Any opinions would be appreciated.
  • Replies 4
  • Clobberwatts
  • Budget Appliance Repair
  • 16345Ed
Are we to assume the issue is no heat?
You never explained what it’s doing or not doing.
Does it ignite at all?
Does ignitor just glow a bit then go out?
Or does ignitor not even energize?
Clobberwatts
Oops. Sorry. Didn't realize I didn't put it in the title.
The ignitor iginites. Glows until I hear a click, with no flame and then the ignitor turns off.
No heat what so ever.
This almost always bad coils - but you said you already replaced them.  Did you replace with new and remember to turn the gas back on if you turned it off?
Clobberwatts
Yes. I have had to do it multiple times because I am using the gas line from my stove. And yes... I am also putting a new flexible on it after I figure out this problem and can put a real line in for this thing.
