Help me know what does this pin do in a washing machine pressure switch/sensor
Go to solution Solved by Budget Appliance Repair,
Hello everyone, I need to know what does this little pin/screw does in a washing machine pressure switch/sensor and what happens if it is completely removed from the switch. Thank you for your time :)
  • Solution
Remove it and you will most likely flood your house!!!
It's the factory adjustment for fine tuning of the water level - It's not supposed to be adjusted by the user, that's why it's paint locked in place.
Adjust at your own risk if you don't know what you are doing and what it is.
  • Thanks 1
