    • 26 April 2025 02:00 PM Until 03:00 PM
      When: Saturday, April 26 @10:00 AM Eastern Time.
Dishwasher Circ. Pump Not Working - Kenmore 665.16039403 - Tech Sheet Needed
Go to solution Solved by RobinWinter,
I am trying to fix my Kenmore dishwasher.  The circulation pump is not turning on.  The rest of the functions of the dishwasher work fine.
I removed the circulation pump and bench tested it.  It ran fine with no noise.
I checked continuity of the wires going from the control board to the circ. pump and all were continuous.
Does someone have a tech sheet for this (or something similar)?  I need the wiring diagram to continue diagnosing.  There is no sheet behind the kick plate or door skin.
Thank you.
  • randy88k5
  • RobinWinter
  • Solution
Pretty simple to diagnose.  Whirlpool is known for failed wash pumps, and this is a whirlpool. It can fail intermittently.  Reassemble the machine if you haven't already, pull the connector off the wash motor,  stick a meter on it preferably set to LoZ if the meter has it, run a test cycle, after it fills you should get ~120vac at the harness.  If you do, replace the motor, if you don't,  replace the board
Robin,
Thank you for the tips.  I reassembled and ran a test cycle.  I saw the 120v coming from the board.  I paused, and hooked it back to the wash pump.  The pump then came on as normal.  I'll be replacing the motor.  Thanks again.
No problem 👍
