Manufacturer: Frigidaire
Type of Appliance: Gas Rabge
Model Number: FFGF3054TSD
With cooktop disassembly please Captain. Thank you!
Rich I see no disassembly on Frigidaire site for you.Maybe the parts list can help! Uploading tech sheet and parts list.Waiting on approval:
The only thing on the electrolux site is the tech sheet.
You can disassemble the cooktop by lifting off all the burner caps, then removing all the screws. There will be 2 or 3 screws under each one.
Gently try to unscrew each one. If any stick, spray with some WD40 wait a minute and try again. If they're seized and you twist hard, they'll snap and you'll be in for an $85 orifice holder and 3 $10 screws.
Once all the screws are gone, the top should just lift off.
Same thing when reinstalling. Gently tighten by hand. The holes are easy to strip and then you'll be buying screws and orifice holders again.
Also the screws are not 1/4", they're 3/16 without a lot of room, so you'll need a 3/16" socket. Possibly a thin-walled socket depending on exactly which burner they used. Some will work with a regular socket, some won't.
This is the socket I use
Edited by Terry Carmen
  • Like 2
Thank you Terry!
Thanks, Cap!
Thank you Son of Samurai!
