Manufacturer: Viking
Type of Appliance: Gas Range
Model Number: VGIS36
PCM tried replacing the two Bake ignitors and failed. Now it’s my turn!
Brother @MVrepairs, are you able to track down anything for this one?
That model number is not complete. It may end with a 0 or 5 maybe. It would also give me some options if you would include the serial number. @Rich Armstrong
@MVrepairs The Model # ends with 0 my apologies. The owner is looking for a Serial # Thank you!
So this is a pretty old unit.  Manufactured in the 90's. This is all viking had.  There should be a schematic on the back side of this range.  It is a pain you have to pull it out, but it should be there in theory.  Also your unit should spark at every burner when any knob is turned to ing.  I hope this helps.
  • Thanks 1
