Hi All,
Background
I had to replace the connector in the attached image, because it was fried due to some water pressure that came out of one of the water hoses.
I replaced the connectors with  some spare faston type connectors at home, so I temporary used them to connect the four wires, and  tested the dishwasher for three days, everything worked perfectly.
In the meantime, I received new faston type connectors from Amazon, I soldered them and insulated them properly.
I set the dishwasher up again and turned it on, but much to my surprise, after 18 seconds, I got the F24 error.
I removed the relay, saw that the contacts were dirty, cleaned them perfectly, but to no avail, F24 is still there.
So I removed the relay again, measured it with a tester, following this procedure, and the relay works perfectly.
I also accessed the panel in 'service mode' and reset the error, but it didn't help.
I did all the component tests, and they all worked as described in the documentation.
  1. The relay contacts are perfect, just like the relay itself. It's extremely clean inside; I opened it up all the way to the last blade, and it looks brand new.
  2. On the connector side, it's the same story – everything is okay.
  3. I removed Plug ST5 from the heater relay and measured the resistance from connector 12 to 22: 284.5 kΩ.
  4. Now, in the English manual, I read 10MΩ, so the 284.5kΩ I found would be significantly lower. Do you know what the correct unit of measure should be?
I removed the pressure switch and performed all the necessary measurements:
11 - 12 = 000.6
With pressure activated = OL
11 - 14 = OL
With pressure activated = 000.15
21 - 22 = 000.1
With pressure activated = 2
21 - 24 = 1.862
It seems unbelievable to me that after I replaced the 8 connectors, I got the F24 error, given that until 30 minutes earlier, everything was working fine.
It would be a hell of a coincidence.
The heater relay looks like new inside.
The heater pressure switch seems to work as expected.
But I know F24 is either the relay or the pressure switch... unless you have a better explanation.
Any help is appreciated.
Thank you
Alex
  • Replies 0
  • Metallo
Posted Images
