    • 01 March 2025 03:00 PM Until 04:00 PM
      When: Saturday, March 1 @10:00 AM Eastern Time.
Manufacturer: Kenmore/Frigidaire
Type of Appliance: Gas Range
Model Number: 79036902900
I need disassembly of the control panel and cooktop knobs. I removed every screw I could see without success.
For the wire diagram it uses 318550111 in this bundle:
Looked over the part exploded view, pull all the knobs. Then unscrew the large nuts Item # 35, then lift off the cover # 19 - Can't remember if there is a ribbon cable. If there is a ribbon cable unplug it and remove cover. From this spot you should be able to figure out the rest of the disassembly procedure.  May want to leave the range with the breaker off during disassmebly.
BTW: the igniter switches are in parallel. 1 switch either came loose or a mounting tab broke.
Edited by Vance R
Added stuff after wire diagram
  • Like 2
  • Thanks 1
