Manufacturer: GE
Type of Appliance: Wall Oven -Electric
Model Number: Could not read - it faded
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): No
I need a service manual with wiring diagram for this electric Walloven, GE.
The model no. on the plate faded with ages.
Thanks.
What's wrong with it?
If it's not cooking check the clock. Most homeowners have no idea how to set the "cook time" and if the clock has stopped working, can get it into a "won't do anything" state because the clock is waiting for a time that will never come.
Hi Terry,
Customer complains the breaker tripping and flash on the back of the control panel when he turns on the bake.  I suppose I can take look at the burnt wire at control section when I get there.  Maybe even be lucky to find the manual sheet tucked away in the back of the control.
Thanks.
Looks like the number is J D 14X1BR.  Have to do some chores, will look later for info.
6 hours ago, Vance R said:
Didn't find any service info, this is as close of a match found.
https://www.repairclinic.com/ProductDetail/639525
Thank you sir.
It turned out the the temperature control part no. wb21x5209 was shorting out and created big sparks when the breaker was turned on position regardless of whether the unit was on or off.
