Maytag Atlantis wash machine; MAV8601AWW ISSUE
During the transition to spin cycle as it appeared the belt was slipping causing burning smell presumably due the trans, motor or drain pump locked up
1. i removed belt; motor and drain pump rotate freely.
2. i can turn the agitator inside drum both CW and CCW maybe 45 degrees before it stops hard
however if i turn the pulley under washer CW and CCW it turns agitator freely.
can one isolate the culprit from this description?
thx much
dave
  • 16345Ed
  • ServiceTech_Daniel
  • davep
ServiceTech_Daniel
Sound's like you have a bad transmission (Gear case) that's locked up
Edited by ServiceTech_Daniel
forgot to add something
Is lip seal leaking?
