Kenmore Elite 665.17464300 Dishwasher No Power
Fodder4Thought
Dishwasher stopped while drying not long ago. No lights on the control panel. Disconnecting power for days and reconnecting did nothing.
I've tested the thermostat on the bottom of the tub, and it shows 0.1 ohms. The fuse at the control board was tested out of circuit, and shows a resistance of 0.1 ohms. I've tested the microswitch in the opening latch, and it works correctly. I found two bulged caps on the control board and replaced them with new ones. I tested the control panel according to the tech sheet that came with the dishwasher, and I think it's ok, but I'm not entirely certain for a few reasons:
1) There are more buttons listed on the tech sheet than exist on the dishwasher.
2) The SOAK & SCOUR button does not exist, and measuring between P1-11 and P1-3 does not produce connectivity from any button
3) The QUICK WASH/QUICK CLEANUP/TIME SAVER button does not exist, and measuring between P1-12 and P1-6 does not produce connectivity from any button
4) The dishwasher has a SMART WASH button, and connectivity is observed when measuring between P1-13 and P1-2, but neither this button nor this combination of pins is listed on the datasheet.
A noncontact voltage detector shows voltage all over the place within the dishwasher carcass - going into and out of the control board, at the handle, underneath the tub, etc.
What's going on? What should I do next?
Any help would be greatly appreciated.
  • Replies 0
  • Fodder4Thought
