Maytag Epic Gas Dryer beeps only when starting cycle.
I have a Maytag Gas Dryer Model MGD9600SQ0. When I turn on the controller every thing looks ok I press start, I here a beep and what sounds like a relay and then it does not start it's cycle. The control panel is still lit. I open the door and push the safety switch in to verify the door isn't the issue and it does the same thing. I pulled the bottom cover to access the blower cover and the igniter. I started with the blower cover,it was pretty dirty but not plugged. I cleaned all the lint and debris from inside and cleaned the blower fins that was lightly caked with hardened lint. Then vacuumed all of the loose stuff out. I also checked the igniter glow start and it is not cracked or looked to be broken in any way I did not touch the element with my hands. I then ordered and installed a new dryer thermal fuse P/N: WP3392519. Not sure where to go from here. We have had this dryer and matching washer for about 18 years. Any help would be greatly appreciated.
  • 3 weeks later...
  • Replies 1
  • dfphoto
  • sgwilliams
Posted Images
you can't just buy parts.... what I learned on YouTube they tell you a lot of things but they only give you 50% of the answers... someone has to test every thing vs factory specs to find the issue....
