      8
Manufacturer: Maytag
Type of Appliance: Washer top load
Model Number: MVW7232HW0
Washer will go through the wash cycle and pump out good and between the 20 min and 17 min spot will not count down and continues to spin. I ohmed out the harness to the motor and it checked good. when I put it into diagnostics then sensor feedback motor speed tach test and spun the tub it was not showing ant change the display stayed on 0. I installed a new main control board and still having the same problem. On this machine does the motor send the rpm feedback to the control I don't see any rpm sensors.
