HELP - Samsung Microwave ME21M706BAG - Lost some functionality
Clems Electric
I have a Samsung microwave (Me21M706BAG) that just stopped working all of the sudden. All buttons and accessories (ie; fan, hood light, timer, clock etc..)seem to be working as normal. When I input the cooking time and hit start I hear a click, the timer on the screen starts counting down and says "Run" as it normally does, but the light inside and the turn table do not run and I'm assuming the magnetron has not turned on as I don't hear or see any real power draw.
I have tried googling the symptoms and came up empty.
Before I go pulling things apart I was hoping to at least get my eyes on a schematic at lease I'd have a better idea of what the problem component may be.
Any help would be greatly appreciated.
TIA
  • Clems Electric
  • Vance R
One of the easy check would the interlock switches and the connectors.
Clems Electric
Thanks.
It sure seems like it may just be something like that since the interior light, turntable and magnetron all don't seem to turn on.
Having not really looked at up to this point other than from the outside. Could you tell me where the access is on these units? Is it in the Back or Top, where the unit will have to be removed? Or is it accessible through the front?
Most appliances I would just get right into, but this one I decided to get more info beforehand since the last microwave I worked on was a wall oven combo and needed a magnetron replaced and there was well over 100 screws just to get to it. I'm assuming this unit is a bit more straight forward.
A wiring diagram would probably be helpful and most appliances I have worked on in the past have them inside.
