Plastic Pieces on exterior of whirlpool dishwasher
Hello- one of these plastic knobs on the outside of my dishwasher was popped off upon unboxing. Do these serve a purpose? Trying to understand if this needs to be fixed before installing. Thank you!
  • Budget Appliance Repair
  • appl.tech.29501
  • JakeGR
Posted Images
Most likely screw guides for side mounting. If you look inside you should see plugs covering the holes. Nothing to hinder proper operation.
No model number supplied - really hard to give much help when you don't included required info.
Not side mounting holes as in suggested in above post.
Even worse - with such a close up picture it's really hard to even determine the orientation of the dishwasher, (looks like it might be on it's back, those might be the guides for a special very thin top/third rack that are used in some models).
