Manufacturer: Kenmore
Type of Appliance: front loader washer
Model Number: 110.49972600
Could not find service manual on this model in the forum.
Thanks.
@topice,I think it would be helpful for you if I showed you how I found it.
Technical sheet #8183018 is the one you want.
To find it, since it's a Kenmore, I had to go to the sears website and look up the parts manual, AKA the parts list or parts diagram, then find the part # of the tech sheet or mini manual and search that number here on appliantology. One document often applies to several different model numbers It's helpful to know that whirpool, for example, calls it a technical sheet. GE calls them mini-manuals. You can use "manual" or "sheet" to search the part manual. Sometimes though, The part manual doesn't have the information you need and I come on here and ask someone to find it who has access. For that, I have to wait though; finding it myself is quicker. I like saving time.
Here's what I found when I searched Appliantology for "8183018"
@vee8power,  thank you so much for this useful tip in finding tech manuals.  I just tried it and it works.  I will be utilizing this technic a lot from now on whenever I get stuck.
