LG electric stove model# LDE3035ST
Go to solution Solved by Chuck Gibson,
Our front, right double heating element has quit working. I checked it to the best of my ability using an ohm meter and the elements appear to be fine. Where do I go from here?
Thanks in advance!
  • Chuck Gibson
  • Daniel.A
After making the initial post I realized that I didn't give enough information..
When the element is turned on, the lights on the display work just fine. I turn it on to high and the display shows "HI". Turning on the select button, the led lights up indicating that the outer ring is on. Unfortunatly, neither element heats up. The rest of the elements and ovens work just fine..
Check for voltage present at the heating element when the element should be on. If it's got adequate voltage, then you'd want to replace the element most likely. You can also visually inspect the coils on the element to see if you find any visible breaks.
  • Solution
Replaced the control board. Stove is now working great!
Thank you!
Chuck
