A part inside the one touch water dispenser cracked - photo attached. Any instructions or video available on how to replace it? I can see there is a hard plastic cover to the assembly but dont know how to remove it - a new cover is $55 on the Samsung site so that could be an expensive mistake. Thanks for any help you can provide.
  • Replies 4
  • ServiceTech_Daniel
  • jmm
Posted Images
ServiceTech_Daniel
Remove the internal water dispenser cover by inserting a flat-blade(-) screwdriver to the gap of dispenser with pulling the cover.
bottom left corner of the dispenser
That was taken from the service manual for that model
ServiceTech_Daniel
I think this is the part number for the dispenser lever DA66-00985A
Thanks! I ordered the part - should be here in a couple days.
ServiceTech_Daniel
No problem, i wish you all the best in your repair :D
