Manufacturer: Kitchenaid
Type of Appliance: refrigerator
Model Number: KSSS36QTW04
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES
Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES
I'VE SEARCHED DOWN to KSSS36Q* and saw the KAR-11 manual, but the dispenser is different, and it is the issue im dealing with.
Original complaint was the ice and water not dispensing, and beeping when either level was depressed, followed by no response, no beeping no nothing for the dispenser. Then a week later the fresh food UI stopped illuminating and then stopped cooling. So I replaced the main control board with the retrofit kit #W10789107, but in confirming all things operational, I had no water or ice dispensing operation, and the beeping when either lever is depressed, but the UI itself is active.
I need the right service manual to see what this beep-beep is when either lever is depressed and what to test for voltage, etc.
thanks
Looks like the info in this bundle is the best that Whirlpool has put out:
You could also take a look at manual 4317344 in this entry to see if it's any closer:
  • Like 2
