Baumatic bwdi1485d Washer Dryer service manual
Baumatic bwdi1485d Looking for service manual, please?
  • Daniel.A
  • cocoat
This is not a common brand, so it might be difficult to find a service manual. I would recommend that you contact the manufacturer and see if they're willing to send you one.
https://service.baumatic.co.uk/advice-centre/washing-machines/bwmi1472dn1/
You can also navigate to the above-listed site for details and contact information.
Well explain problem and and what was done maybe some can shed some light
E01 error is being displayed and can't clear the follow was done.
Drain filter cleared
Drain pump was removed and clean
The drain hose was cleared
Water inlet hose was check for water
Filter for water inlet is clean
Unit was even powered down for several hours,
still Error continue, please advise on possible reason for issue or how reset to unit thank you.
Okay. So let's start at the beginning. When you go to start a cycle, you shut the door and press start, and the error code appears? No cycle starts to any degree?
I looked through a few Baumatic washer service manuals, and the E01 error code appears to point toward a faulty door latch. I would assess that first.
And FYI, I don't get notified of a response if you don't tag me or quote me in it. If you type out @Daniel.A, it will tag me so I can get notified.
