Heating element goes on, then goes out without igniting flame.
We're going to need some more information, such as the model number of the appliance.
Since you mention that there is no flame, I'm assuming you're talking about a gas appliance. The heating element on a gas dryer is called an "igniter." The term "heating element" is generally associated with electric dryers.
Basically how gas dryers ignite is this: Voltage is sent to the igniter. The igniter heats up until the flame sensor on the blower housing detects enough heat, where it then opens a circuit and directs voltage to the coils, which engage and send gas past the igniter which should in turn ignite the gas.
Lacking a multimeter, I would start by replacing the coils as they tend to go bad.
When you don’t know a heating element from an igniter I recommend calling a professional tech.
  • Haha 1
2nd this
