Manufacturer: GE
Type of Appliance: Dishwasher
Model Number: PDT720SSH7SS
I need the actual service manual for this specific model to troubleshoot a no heating issue.  Similar models have different instructions and different operation / behavior of the test mode.
You should be able to use this service manual:
This mini manual:
This service bulletin:
Quote:
If the dishwasher is not heating, even in test mode. ALWAYS disconnect the wire harness from the float switch and test the heater again, BEFORE replacing any other component. 99% of the time, the float switch is the problem.
this does assume that the issue is no power coming from the main control board
Float switch part # WD21X10519
