Looking for service manual for Frigidaire refrigerator GRFS2853AF0.
Manufacturer: Frigidaire
Model Number: GRFS2853AF0
Howdy,
I am trying to locate the service manual for this refrigerator. It is displaying "OFF" and I cannot figure any combination of buttons to change the status or enter a service mode.
Thank you for your help,
doolie
Edited by doolie0
Added thanks
Tech Tip RFTT2206
1.) If the display is not illuminated but the unit is cooling, the UI Sleep Mode is activated.
2.) If the display reads OFF and the unit is not cooling, the power was turned off on the
unit.
1.) To change from Sleep Mode to Active Mode (UI display stays lit), simultaneously
press and hold CRUSH and Light for 5 seconds. The display will show the current
temperature/ice maker status.
2.) To change from OFF mode, simultaneously press and hold CUBE and Light for 10 seconds.
Uses the same tech sheet as this model:
Edited by Captain Dunsel
  • Like 2
5 hours ago, Captain Dunsel said:
Tech Tip RFTT2206
unit.
Thank you very much. I was unable to find that while searching.
Do you have a tip that could have helped me find that? I was searching files and removing one character at a time while using the wildcard *
@doolie0 Page 60 in this Electrolux Tech Handbook 2023
