Whirlpool Washer WTW5700SW0 -- Odd Noise While Spin/Drain Cycle
Hi All,
I replaced my shaft seals as they were leaking as well as the outer tub gasket and new clutch. After I reinstalled everything I started hearing an odd noise when the drum gets up to speed.
Here is a clip of the noise
https://drive.google.com/file/d/1RUV6IiuT3ZFZYJieVCq78N5t6f6N6D1Y/view?usp=sharing
Here is the transmission out of the washer with just the motor attached and running
https://drive.google.com/file/d/1EU7-XS5u8x5u5fdT_ONR4BnlK-g5nQiD/view?usp=sharing
Does it sound the same? Is the issue with the transmission? I did have a little gear oil leak out of the top so I do need to get a new seal. Just wondering if I need a new transmission and if this is what is causing the noise.
Any help would be appreciated. This noise was not there before I installed the seals for the shaft.
  • Replies 0
  • npolite
