Manufacturer: LG
Type of Appliance: Dishwasher
Model Number: LDT7808BD/00
The parts diagram lists two different part numbers for this model but you're supposed to select the right one based on a service bulletin from LG that tells you there's a part number change for the main control after a certain serial number.  Does anyone have the service bulletin please?
Fun times, found 3 different files for main board/ harness info. @Ananda probably needs cdz20160000-3 for correct board, to be safe should look over all 3. Uploaded pending approval:
Service manual is here:
  • Thanks 1
Thanks, Vance! Approved.
