New Appliance Service Manual added: Thermador Cooktop Solenoid shorting IRIS XLO Service Bulletin
View File
PUB 58300000232414
Models:
PCG305W/01 PRD364WIGU/01 - 05 PRD486WIGU/01 - 05 PRD606WESG/01 - 05
PCG364WD/01 PRD364WLGC/01-05 PRD486WLGU/01 - 05 PRG304WH/01 - 05
PCG364WL/01 PRD364WLHU/01 - 04 PRD486WLHU/01,02,04,05 PRG305WH/01 - 05
PCG366W/01 PRD366WGC/01,02,04,05 PRD48WCSGC/01,02,04 PRG364WDG/01,04,05
PCG486WD/01 PRD366WGU/01 - 05 PRD48WCSGU/01,02,04,05 PRG364WDH/01 - 05
PCG486WL/01 PRD366WHC/01 - 05 PRD48WDSGC/01,02,04,05 PRG364WLG/01,02,04,05
PRD304WHC/01,02,03 PRD366WHU/01 - 04 PRD48WDSGU/01,02,04,05 PRG364WLH/01 - 04
PRD304WHU/01,02,03 PRD484WCGU/01,02,04,05 PRD48WISGC/01,02,04,05 PRG366WG/01,02,04,05
PRD305WHC/01,02,03 PRD484WCHU/01,03,05 PRD48WISGU/01,02,04,05 PRG366WH/01,02,03,04
PRD305WHU/01,02,03 PRD486WDGC/01,02,04,05 PRD48WLSGC/01,02,05 PRG486WDG/01 - 04
PRD364WDGC/01,04,05 PRD486WDGU/01 - 05 PRD48WLSGU/01 - 05 PRG486WDH/01 - 05
PRD364WDGU/01- 05 PRD486WDHC/01,03 PRD606WCG/01 - 06 PRG486WLG/01 - 04
PRD364WDHC/01,03,04 PRD486WDHU/01,02,03,05 PRD606WCSG/01 - 05 PRG486WLH/01,02,03,05
PRD364WDHU/01,02,04,05 PRD486WIGC/01,02,04,05 PRD606WEG/01,02,03,04,,06
  • Son of Samurai
  • Far field
I don’t understand “coil shorting” as a best describtion of the trouble. Is this to mean intermittent shorting or the coil burns out or what exactly. We have to assume a lot. If this trouble is that it’s intermittent it could be the coil but I’m more aptly convinced to eliminate all else.  Age of the part? Type of operation the Solonoid coil / valve / operator does.
an amp draw and voltage at that time would also help as well as the wattage and resistance of the coil.
I agree that it's vague, but that's the title Bosch gave for the bulletin, so I figured I would preserve it. Uncertain if they actually mean shorting in the technical sense, and there's no clarification on that in the bulletin itself.
