WM2450HRA LG washer must be unplugged between use
Hi all!
Our WM2450HRA LG washer will only work if unplugged and plugged back in after each use.  If you do a quick plug and unplug, it won't fix the issue but if you wait 20 - 30 seconds, there will be a spark and "pop!" at the outlet then it will power on.
From a bit of digging online, it seems this is a symptom of a relay on the mainboard (EBR64144911) going out.  Unfortunately, the mainboard is no longer available so it will be a continual unplug/plug until it finally let's out the blue smoke.  That being said, has anyone attempted to replace the relay?  Last year a relay went out on our oven control board and I was able to de-solder it and replace the relay ($2.50 part as opposed to a $250 board!).
Any other suggestion?  I'd like to keep this going as just a few months ago I replaced the main bearing and washing tub support!
Thanks much!
  • Replies 0
  • Lost Dog
