Manufacturer: Alliance Laundry systems
Type of Appliance: Stacked front load
Model Number: ATEE9ASP175TW01
Hello! I have looked around the stacked homestyle manuals and found the 1.0 version which has been very helpful.
I need additional resources on how to go into test mode with this stacked washer and dryer unit with the split ui system. I will upload a picture of what the machine ui looks like vs the only manual I’ve found on Applaiantology.org
Thanks  so much for your help!
I assume this is the one you've been looking at. @Adirondack Bob, is there any more info out there on this model, or is this manual the best there is?
All I see is the Troubleshooting Manual
Thank you both for looking into this.
