MDB8751BWQ dishwasher new pump gasket has flaky white substance
empirical_tuna
Yep, first time I'll be replacing a dishwasher pump assembly gasket. I received the new part 12002361 in a sealed "Whirlpool Corporation" plastic bag that also says "made in US 11/07/22."
This gasket is partly covered in a white substance that is flaking off inside the bag (please see attached photo).
Is something wrong with it?
  • empirical_tuna
Posted Images
My guess is it has something to do with making the rubber.  They add a white powder when vulcanizing; I suspect that is it and everything is fine.
I should add you probably should wash it with dish soap and dry thoroughly before installing.  There may be some sort of lubricant suggested, I don't know. I think if I was doing it I would consider a thin coating of plumbing grease which is availbe at home depot near the PVC glue and such.
