Manufacturer: GE Monogram
Type of Appliance: Freezer
Model Number: ZIF361NPRAII
Ice maker, no ice.  Found no water in  mold so powered inlet valve and water leaves valve (with line to IM disconnected of course) but will not make it to ice maker.  Removed fill tube, not frozen there.  Must be frozen elsewhere.  It appears this line probably runs inside of walls of unit and is not accessible??  Is this the case?  I do not want to pull that huge thing out just to find nothing on the back of it.  The line goes up into the unit about middle ways.  I think there must be a void in insulation or something that has caused the ice maker line to freeze.  Any help? Thanks.
  • Replies 5
  • Captain Dunsel
  • ApplianceMagic
  • AustinHines
Unless someone else has a service manual.I only see a mini manual.Uploading and waiting on approval:
Here is that mini manual:
@ApplianceMagic I put the wrong model on the mini manual, but it takes the same manual #.
Thanks!
Water is coming out of water valve to IM? Try steaming from fill tube.
