My six year old Maytag MEDB765FC0 dryer recently stopped drying completely. I’ve replaced just about everything I can with no improvement.
I’ve installed a new heating unit, sensor bars, thermistor, thermal cutoff, and thermal fuse. All tested for continuity. I also cleaned the exhaust duct.
looking for any suggestions on what to try next.
ServiceTech_Daniel
Are you receiving 220Vac at the terminal block? it's good to check with a loading meter, or a meter with LowZ function to eliminate any ghost voltage.
L1 to neutral should be 110
L2 to neutral should be 110
You can split the circuit at the element , take one of the terminals off ((power unplugged))
Move it out of the way not touching anything.
Plug it back in(The power cord) , turn the dryer on to heat . You should have 110 coming off both wires with respect to neutral.
If one of the wires doesn't read 110 from the wire to neutral , that is where you are losing your second leg of 110 , either the motor , or the control/timer
Edited by ServiceTech_Daniel
Is it heating? Long dry times can be caused by airflow or venting issues
