Whirlpool Range Mod KFGC506JSS00 Shuts down Bake Burner quickly after Relight
Manufacturer: Whirlpool
Type of Appliance: Range
Model Number: KFGC506JSS00
Need Tech Manual after Range shuts down Bake burner during relight. You can watch the burner relight normally, as this model uses a spark ignition system, but after it quickly relights, the spark ignition continues firing for 6 or 7 more sparks, then the flame is quickly extinguished. Seems the unit determines it didn't relight, even though it does. I imagine its a flame block type of flame detection, and it's not working correctly for some unknown reason... Thanks for any and all help!!!
Uses this service manual:
Uploading tech sheet, wiring diagram and waiting on approval:
Thanks, Cap!
Thank you both!!!
