Manufacturer: Thermador
Type of Appliance: Oven
Model Number: CT230S-01
Wiring diagram is needed, and board view if it is possible. There is a definitely problems with the board but it's discontinued, some elements of it should be replaced.
Edited by Eli Sabayev
  • Replies 4
  • Eli Sabayev
Posted Images
14 hours ago, Eli Sabayev said:
Model Number: C1230S-01
That model number doesn't pull up anything at the Bosch site. Doublecheck and post the corrected model number. Post the FD number, too. (the two digits after the "/" in the model number.)
Yes, it's actually CT230S/01
Bosch has very limited info on this old cooktop and no board pinouts. I don't know if I've ever seen a Bosch board pinout. They may exist but must be rare. No wiring diagram, either.
That service manual you found is the best info available for this model.
