Model Number: KEBC278KSS03
I had some electrical work done at my house yesterday and when the power was restored, the oven is showing an E1 F5 error code on the display panel.  The upper oven will not work but the lower oven will.  I've tried cycling the breaker and cutting power to the unit for up to 15 minutes but the error code will not clear.  This happened a few years ago after a power outage and I was able to find a procedure online to reset the panel by pressing a combination of buttons on the control panel, but I can't find it anywhere.  Any recommendations?
  • Replies 1
  • rexus31
Posted Images
The issue has been resolved by hitting Lower Oven Cancel, Upper Oven Cancel and Start. Door Locked appeared on the display for 30 seconds, went away and the error message is gone.
